Hey folks, Was recommended this project by a fellow home brewer and after reading up, I look forward to getting it online. There seems to be a wealth of information and support on this forum so here’s hoping someone is able to point me in the right direction! (please).
I work in IT and have some exposure to Linux/Unix systems, I have limited experience and am comfy with nano/VI and CLI commands. Im building my kegberry on a Raspberry Pi 2B that I have from a previous project, Arduino and flow meters on order! (thank AliExpress).
I’ve got all the dependencies installed (I believe) and have the Pi system / firmware updated. I’ve reached the point of trying to install kegbot and keep hitting an error. One thing upfront - I am using the latest release of Raspbian Jessie and have identified some dependance require ‘default-’ prefixing to install - which I have done.
The error I get is
Command "/usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-cIDqL8/MySQL-python/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-nWsa3Q/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-cIDqL8/MySQL-python/
Full install output is here: https://www.icloud.com/iclouddrive/02SOECX_mZQ9r5RYXxR4GmOOg#output
I suspect I have missed a step or something, any help would be greatly appreciated.
Andy
