Hi, I’ve managed to get Kegberry installed on a Model B Raspberry Pi. At first, I tried a clean raspbian install with the curl command for the install, but i ran into issues with it frequently locking up. I’ve updated the SD card, and still had similar issues, so I re-imaged the new card with the kegberry image.
I was able to run through the web setup, and add my first keg to the database, but then I started to get 504 errors when accessing the web server.
I have not turned off the debugging or fixed the email. Could that be causing this issue?..I figured out that I have to change to the kegberry user (not kegbot as it says in the instructions), but I don’t know what the password is.
We haven’t had chance to do much testing on the original (256mb) model B. I suspect scarce memory is leading the system to thrash and timeout serving requests.
Thanks for the update. So it’s a bit over 24 hours later and I wanted to report. I was having the same error so I decided to move the root filesystem to a usb stick.
Following the instructions here, I was able to get the gist of how to do this.
I did not follow the directions exactly. For moving the partition, I actually used gparted on a separate linux machine. Near the end, he includes instructions on how to change the linux swapfile size. I made the size 256mb – I also had to kill celery and redis-server to free up enough RAM to allow me to made the changes to the swap file.
Performance has definitely improved, at the command line and in the web interface.
I’m testing it out by taxing the server…uploading image files for beers and users (this crashed it before) with mixed results. I ended up getting a 500 error on the main page after uploading a new image for a beer but strangely, I was able to access other pages, but not the main dashboard…and unlike before this remained persistent after the reboot (I can see the new beer – which was strangely duplicated).
At this point, I’m getting tempted install the server on my netbook instead.
So, it’s still running with increased RAM (well, increased swapspace anyway) and I was able to update/upgrade raspbian and kegbot from the command line. Through the browser, I can access every page EXCEPT the dashboard where I’m getting a 500 server error.
The kegbot logs are giving the following error:
File "/home/kegberry/kegbot-server.venv/local/lib/python2.7/site-packages/pykeg/web/api/middleware.py", line 72, in process_view
util.check_api_key(request)
File "/home/kegberry/kegbot-server.venv/local/lib/python2.7/site-packages/pykeg/web/api/util.py", line 64, in check_api_key
raise kbapi.NoAuthTokenError('The parameter "api_key" is required')
NoAuthTokenError: The parameter "api_key" is required
So I should clarify. It’s not the dashboard page that’s the problem. The link to dashboard brings up my.ip.address/kegadmin. The only page that does not appear in the browser is the root home page at my.ip.address.
Here’s the full error:
Oct 6 2014, 1:40 a.m. (pykeg.web.api.util) NoAuthTokenError: The parameter "api_key" is required
So I tracked the two errors to this one in util.py:
def check_api_key(request):
"""Check a request for an API key."""
keystr = request.META.get('HTTP_X_KEGBOT_API_KEY')
if not keystr:
keystr = request.REQUEST.get('api_key')
if not keystr:
try:
api_key = models.ApiKey.objects.get(key=keystr)
except models.ApiKey.DoesNotExist:
raise kbapi.BadApiKeyError('API key does not exist')
if not api_key.is_active():
raise kbapi.BadApiKeyError('Key and/or user is inactive')
# TODO: remove me.
if api_key.user and (not api_key.user.is_staff and not api_key.user.is_superuser):
raise kbapi.PermissionDeniedError('User is not staff/superuser')
…and this one in middleware.py:
class ApiRequestMiddleware:
def process_view(self, request, view_func, view_args, view_kwargs):
request.is_kb_api_request = util.is_api_request(request)
if not request.is_kb_api_request:
# Not an API request. Skip me.
return None
try:
if request.need_setup:
raise ValueError('Setup required')
elif request.need_upgrade:
raise ValueError('Upgrade required')
need_auth = util.needs_auth(view_func)
privacy = request.kbsite.privacy
if request.path.startswith(WHITELISTED_API_PATHS):
# API request to whitelisted path.
need_auth = False
else:
# API request to non-whitelisted path, in non-public site privacy mode.
# Demand API key.
if privacy == 'members' and not request.user.is_authenticated():
need_auth = True
elif privacy == 'staff' and not request.user.is_staff:
need_auth = True
if need_auth:
return None
except Exception, e:
return util.wrap_exception(request, e)
…so it seems like something’s wrong with the api key…but it appears when i log in…any ideas?
