Hello,
I see in the pictures of the Kegberry that the monitor appears to measure drinks poured in pints. Is there a simple option to switch all the measurements to ounces, or will it only do that when a keg is low? If there is no way to manually change all kegs to ounces, is there a way to change the serving size from 16 ounces to 14 ounces?
Thank you to anyone able to answer me
