I had the first couple kegs work perfectly on my new build, but I’m trying to attach a keg to a tap and I keep getting error 500s on both of the taps. Not really sure how to look into this at this point. Any hints would be appreciated!
Well… I logged in and tried tab-completion and that failed. That always tells me the disk is full, which is the case. I’ll look to see where the leak is.
That fixed it. I deleted a couple of the logs, then ran raspi-config to expand the partition. Now I’m at 25% of a 16 gig disk, and the kegs were added just fine!
I think I’m having the same issue. How did you delete the logs?
