Esp32 connecting to Server..But how?
Hi everyone
Managed to get Kegbot running nicely a few years ago using raspberry Pi as server and Arduino as kegboard for flow meters. Unfortunately my Freezer(Keezer) died and so did my will to live, briefly). I how ever recently decided to get things going again from scratch but using esp32 board instead of Arduino. Im new to esp32 boards so things are slow and painful to set up.
I have managed to install the server on the Pi, and flashed the kegboard4 firmware on esp32.
( Successfully I think).
Im currently stuck at pairing the board and server.
As per official documentation…“Point the board at your server’s /api/kegboard-event URL”
Im not sure where and how to do this, any help will be appreciated.
It seems my issue is installing firmware correctly…
Get a configuration
Start from an example:
git clone https://github.com/Kegbot/kegboard.git
cd kegboard/examples
cp secrets.yaml.example secrets.yaml
Update: managed to get the kegboard (esp32) paired, but only with v2 of kegserver.
The current verion (1.3) refuses connection of kegboard (error 404)..I have tried everything I can think off…this is my reporting url.
http://192.168.1.63/api/kegboard-event
A 404 usually means the request reached the server but no route matched, so I’d check the path and method before re-pairing. Try the URL with a trailing slash in a browser as a GET: if that also 404s, the route genuinely isn’t registered in 1.3, and the firmware is posting to an address that moved. Worth checking the server’s URL configuration and the access log to see exactly what path and method arrive. A missing API key would normally give 401/403 rather than 404, so auth seems less likely than a changed endpoint.
