Just got the kegbot working installed and my pour volumes are way off. Guessing about it registering half to a third of what volume has went through the meter. I expected this thing to be somewhat accurate without calibration. Is this possibly a build issue. Is calibration always necessary?
What meters and what servet version of the are you using? As I understand it there was a change in the settings for calibration in the current build to reflect kegbot moving to using the Ft 330 meter. You should be able to fix this by running the calibration wizard on the tablet front end.
I am on build 84 and using the ft330.
I seem to have it calibrated pretty close now. Keg just kicked so I did it with the cleaning solution.Much easier than pounding.trip IPA at 13.25%.![]()
