Hi,I am new to RPi and have just setup a kegberry, I have tried to change the “DEBUG = True” to “DEBUG = False”. However when I try to save the changes it gives me an error message of “Can’t open file to write”, please help.
Try this:
sudo su - kegberry
vi ~/.kegbot/local_settings.py
You can use nano
instead of vi
if you prefer.
If the sudo command fails, use sudo su - kegbot
Excellent thanks for the help, I have changed the DEBUG to false.
I did this using nano but nothing happens. I still can not modify local_settings.py
as soon as I set debugging to false i can no longer connect to my Raspberry Pi over my network. Comes up with 502 error. Any thoughts? Im new so let me know what I should include to get better advice. Thanks!
