This error typically occurs with a nginx and supervisor [production setup] (Page Not Found | Kegbot) under three common scenarios.
Scenario One: Kegbot Server Won’t Load
You will see this error if:
nginxis running andsupervisoris not running [AND/OR]- There is a misconfiguration between your
supervisorandnginxconfiguration files
Please refer to the [production setup] (Page Not Found | Kegbot) documents, make any necessary changes to the configuration files, reload/restart supervisor, and restart nginx
Scenario Two: Modifying a Drink
When modifying a drink, Kegbot Server recalculates global statistics. Depending on the length of your drink history and the power of your server’s CPU, this can take a long time and may cause a timeout.
In kegbot-nginx.conf within location / declaration, add the following:
proxy_connect_timeout 300s;proxy_read_timeout 300s;
In kegbot-supervisor.conf under [program:gunicorn]:
- Append
--timeout=300to the end of thecommandline
Reload/Restart supervisor and restart nginx
If you still receive the 502 error, try increasing the timeout number.
Scenario Three: Triggering an E-mail Event
Kegbot Server can be configured, by user, to trigger e-mails when four events occur. Keg Start, Keg End, Session Start, Keg Volume Low. If your e-mail parameters are misconfigured, you may witness a 502 error on any of these events.
Be sure e-mail is set up properly
- Read the docs
- If using Gmail, visit our configuration settings tutorial
Alternative to E-mail (Workaround if e-mail is unconfigured)
- Go to
Account -> Notificationsarea and un-check ALL the notifications
And Remember…
We regularly update the Kegbot Server software, and your particular problem may have recently been fixed.
Kegbot Server Upgrade
- Follow [these steps] (Page Not Found | Kegbot)
