Issue with "Sessions" after backup\restore
Okay so I have been able to my on premise setup going again. Had to manually reset all the passwords from my ‘keghub’ site restore so that’s something that should probably be added to the KB. In any case I have one remaining issue. Whenever I click on “sessions” on my Kegbot website I am getting a “Server Error (500)”. Everything else seems to be working including email and twitter, I can browse around without issue and even pull up sessions manually but I simply can’t click on “Sessions” without the server error. Anyone have any idea as to the why?
Jeff
See troubleshooting instruction here
Thanks Mike, I’m getting the error “no database selected” running that command. My googling says I need to specify my kegbot DB at the end of the command instead of “mysql”. When I run “mysql_tzinfo_to_sql /usr/share/zoneinfo | mysql -u root -p kegbot” I get “Error 1146 (42S02) at line 1: Table ‘kegbot.time_zone’ doesn’t exist”.
Thoughts?
Thanks!!!
Jeff
Okay so once again Mikey rules and my attempt to outsmart the very simple command… In any case thanks Mike for pointing that step out and my apologies for not being able to read. In any case the command fixed the issue and all is well now.
You may close.
Jeff
