This is probably not be because of it running on a raspberry pi, but wanted to include the info just in case.
I currently have kegbot installed and running on a Rasberry Pi. I also have the kegbot android app running, with it set to connect to a server. I used the link provided during setup of the app, and it is able to communicate with the kegbot server (images, kegs, volumes, etc show on the tablet). When I select a tap, and authenticate on the tablet, the pour always stays at 0, and the kegbot web interface shows as a guest pour.
Where would be a good place (which logs/etc) to start to troubleshoot this issue?
Server - App version: 2.1.1
Android - App 1.0.0 beta 84
Worker Name Status
default@raspberrypi ok
stats@raspberrypi ok
kegbot 3131 0.0 0.6 4608 2916 ? Ss 18:46 0:00 -su -c sleep 10; /home/kegbot/kegbot-server.venv/bin/kegbot run_workers
kegbot 3134 0.0 0.6 4608 2880 ? Ss 18:46 0:00 -su -c sleep 20; /home/kegbot/kegbot-pycore.venv/bin/kegboard_daemon.py
kegbot 3136 0.3 2.5 14432 11372 ? Ss 18:46 0:03 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/gunicorn pykeg.web.wsgi:application --timeout=120 -w 2
kegbot 3150 8.5 7.7 49480 34416 ? S 18:46 1:11 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/gunicorn pykeg.web.wsgi:application --timeout=120 -w 2
kegbot 3152 2.2 6.1 33800 27488 ? S 18:46 0:18 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/kegbot run_workers
kegbot 3166 18.0 2.5 14368 11312 ? S 18:46 2:27 /home/kegbot/kegbot-pycore.venv/bin/python /home/kegbot/kegbot-pycore.venv/bin/kegboard_daemon.py
kegbot 3197 0.0 0.2 1760 1048 ? Ss 18:47 0:00 /bin/sh -c celery -A pykeg worker -l info -Q stats --concurrency=1 --hostname=“stats@%h”
kegbot 3198 4.9 7.1 39392 32076 ? S 18:47 0:38 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q stats --concurrency=1 --hostname=stats@%h
kegbot 3199 0.0 0.2 1760 1148 ? Ss 18:47 0:00 /bin/sh -c celery -A pykeg beat --pidfile= -l info
kegbot 3200 2.6 6.7 36812 29912 ? S 18:47 0:20 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg beat --pidfile= -l info
kegbot 3201 0.0 0.2 1760 1144 ? Ss 18:47 0:00 /bin/sh -c celery -A pykeg worker -l info -Q default --hostname=“default@%h”
kegbot 3202 5.1 7.1 40416 32092 ? R 18:47 0:40 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q default --hostname=default@%h
kegbot 3277 8.0 7.5 48568 33512 ? S 18:49 0:53 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/gunicorn pykeg.web.wsgi:application --timeout=120 -w 2
kegbot 3278 0.0 6.2 39700 27648 ? S 18:49 0:00 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q default --hostname=default@%h
kegbot 3279 0.0 6.2 39700 27652 ? S 18:49 0:00 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q default --hostname=default@%h
kegbot 3280 0.0 6.2 39700 27652 ? S 18:49 0:00 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q default --hostname=default@%h
kegbot 3281 0.0 6.1 38548 27564 ? S 18:49 0:00 /home/kegbot/kegbot-server.venv/bin/python /home/kegbot/kegbot-server.venv/bin/celery -A pykeg worker -l info -Q stats --concurrency=1 --hostname=stats@%h
root 3335 0.0 0.4 2908 1920 ? S 18:50 0:00 su -l kegbot -c sleep 15; /home/kegbot/kegbot-pycore.venv/bin/kegbot_core.py --flagfile=/home/kegbot/.kegbot/pycore-flags.txt
kegbot 3336 0.0 0.6 4608 2916 ? Ss 18:50 0:00 -su -c sleep 15; /home/kegbot/kegbot-pycore.venv/bin/kegbot_core.py --flagfile=/home/kegbot/.kegbot/pycore-flags.txt
kegbot 3341 3.3 3.2 58268 14480 ? Sl 18:50 0:20 /home/kegbot/kegbot-pycore.venv/bin/python /home/kegbot/kegbot-pycore.venv/bin/kegbot_core.py --flagfile=/home/kegbot/.kegbot/pycore-flags.txt
