Kegberry on RPi 3
Ok, doesn’t look like anyone has seen the kegberry data loss problem before so I figured I just start again on a new Pi and see how it goes.
Grabbed a Pi3 Model B V1.2 and tried the kegberry install. It starts off ok but I get a message just a short way into the that says
import six
ImportError: No module named six
Any help on this one much appreciated.
Cheers, Steve.
Disregard so far, google helped with finding six and the install is now progressing.
What OS are you using? Or Are you using the kegberry recommended image?
I just loaded Raspian and then ran the Kegberry install command. It all worked fine on the Pi3 once I had found and installed the six module.
