Hi,
I have struggled for weeks with my flow meter and temp sensor. The flow meter was reporting ticks continuously with the tap closed and the temp sensor did not show up at all. This is a picture of the adapter I was using for “easy connection” to the KBPM.
When I soldered the original RJ-45 back on everything started working. The flow meter ticks stopped running so that I could calibrate the meter properly and the temp sensor showed up immediately. I don’t know why the adapter didn’t work but the main thing is that everything is working now.
Hope this can be useful information to those of you that are having problems with the flow meter and/or the temp sensor.
/Bjorn
