The app is getting all of the pours from the server. I am presently at a -11.2 pints since I was unable to calibrate when I installed the app. Any ideas? I was going to uninstall and re-install the app next.
My app says the flow sensor does not exist. Same with you?
Edit: “not connected” instead of does not exist.
Hi,
When I installed my flow sensor I used a different RJ45 connector instead of the original that came with the sensor (because I plugged in some other hardware also like temp sensor and solenoid relay). I had the same problem with nothing showing up, but when i switched back to the original RJ45 connector everything stated working with all sensors.
Try switching back to the original RJ45 connector if you are not using it.
/Bjorn
