I am building my own application to communicate with a kegboard using the serial protocol. I have quite a bit of it figured out but am having an implementation issue.
There is a watchdog timer on the relays that turns them off after approximately 12 seconds. I need to either be able to turn this functionality off or increase the time.
The serial protocol documentation alludes to there being a set_configuration command that can be used to change the setting of the watchdog timer but I don’t see any documentation for that command.
Any ideas?
Please advise.
Thanks.
John
