Android Verified Compatible Tablets
The following tablets have been verified to be compatible with Kegbot. Compatibility is defined as supporting the Kegboard as a USB device as well as the capability of being charged at the same time. The compatible tablets are listed here in alphabetical order. Please see the buyers guide for recommendations.
[Acer Iconia A210] (http://amzn.com/B009HPGO7M?tag=kegbot-20)
Works out of the box! Contains a full-size USB port and a dedicated power supply
Alldaymall A70M Dual-Core [Discontinued] - Do NOT get the A23 model!
Notes:
  • Tablet resolution is pretty low (800x480) so some UI functions aren’t ideal
  • Verify that you are purchasing the A70M and not another AllDayMall tablet version! Amazon is recycling ASINs, and even ‘color choices’ on the A70M product page sometimes point to different tablets.
Alldaymall w/ Allwinner A13 [Discontinued] - Do NOT get the A23 model!
Requires:
Notes:
  • Contains a dedicated power supply
  • Verify that you are purchasing the A13 and not another AllDayMall tablet version! Amazon is recycling ASINs, and even ‘color choices’ on the A13 product page sometimes point to different tablets.
[Dell Venue 8] (http://amzn.com/B00FFVYSKW?tag=kegbot-20)
Requires:
[HP Touchpad] (http://amzn.com/B0055D67HW?tag=kegbot-20)
Requires:
Notes:
  • CM10.2 - AOSP 4.4.2 are not compatible
  • USB OTG Power-Y does not charge the tablet
Known Bugs Unique to this Device:
  • When registering a new user through the tablet interface, the camera display is blank but the picture is taken, saved, and in the correct orientation
  • When taking a photo associated with a pour, the camera display is visible and in the correct orientation but the image is saved upside-down.
[iDeaUSA CT705] (http://amzn.com/B00DQBLK0Y?tag=kegbot-20)
Requires:
Notes:
[iDeaUSA CT720HD] (http://amzn.com/B00IDNGU7S?tag=kegbot-20)
Requires:
Notes:
[Motorola Xoom] (http://amzn.com/B0045FM6SU?tag=kegbot-20)
Works out of the box! Contains a micro-USB port and a dedicated power supply
[Nexus 7 (2012)] (http://amzn.com/B009X3UW2G?tag=kegbot-20)
Requires:
Notes:
  • Pogo pin charging dock does not work when Kegboard plugged into micro-USB port
[Nexus 7 (2013)] (http://amzn.com/B00DVFLJDS?tag=kegbot-20)
Requires:
Notes:
  • Qi induction charger does not work when Kegboard plugged into micro-USB port
  • NFC does not work when Qi induction charger in operation
[Nexus 10] (http://amzn.com/B00ACVI202?tag=kegbot-20)
Requires:
Notes:
  • We’ve heard that rooting the Nexus 10 is the exact same procedure as rooting the Nexus 7, but have not independently verified.
[ViewSonic VSD241] (http://amzn.com/B00DSUTG4U?tag=kegbot-20)
Notes:
  • The device’s power supply to the Kegboard can be unstable. Use a powered USB Hub for a stable power source.
