Did you ever find any fittings for your flow meters?
Hey @celblazer - did you end up getting the generic arduino boards to work?
I’m currently trying to get a generic Mega to work. Connects to the PC OK - Arduino software ‘sees’ the board. I flashed the firmware, which seemed to work fine. But the board doesn’t seem to “transmit” - even when using the test pin 12 only the Rx light flashes, not the Tx. So looks like it’s not communicating properly.
Never got around to building one. Sorry.
NFC works out of the box if you have a tablet that uses nfc. Otherwise you’d need to wire an nfc reader to your arduino
