Set up Kegbot on a cloud server in under 15 minutes. This guide will walk you through deploying Kegbot Server on Digital Ocean, although the steps may work on other cloud providers.
##Step 1: Create a new Digital Ocean droplet
Sign Up for Digital Ocean, add your billing information, then create a new droplet (virtual server).
- Under Droplet Hostname, enter a name like
my-kegbot. - Under Size, you may select the smallest size droplet; larger servers will perform better.
- Under Select Image, select Ubuntu 14.04 x64.
Press Create Droplet. You will receive a mail from Digital Ocean with the root password to your droplet.
Step 2: Connect to your droplet
Connect to your droplet using the ssh command-line tool (Mac, Linux) or using Putty on Windows::
ssh [email protected]
Replace 192.168.1.2 with the IP address of your Droplet.
You will be asked for permission to connect, type yes, then enter the root password from the email Digital Ocean sent you when the Droplet was set up.
Step 3: Install Kegbot Server using the Kegberry script
Paste and run the following commands exactly as shown below::
export INSTALLFLAGS="--nopycore --allow_root"
bash -c "$(curl -fsSL https://raw.github.com/Kegbot/kegberry/master/install.sh)"
While running, the script will:
- Install all Ubuntu system dependencies (nginx, redis, and so on).
- Create a new user named
kegbotand home directory/home/kegbot. - Create and install the Kegbot MySQL database named
kegbot. - Install the Kegbot daemons and start the server.
Step 4: Complete the setup wizard
Navigate to the IP address of your system: http://your-ip/. You should be greeted by the Kegbot Setup wizard. Complete the install and you’re ready to go!
Next steps
The kegbot user
Important: The server is installed under the kegbot user, so to update or modify the Kegbot install, you need to become the kegbot user first using sudo:
root@my-kegbot:~# su - kegbot
kegbot@my-kegbot:~$
To run kegbot commands such as kegbot upgrade, you also need to activate the virtualenv before running any command::
kegbot@my-kegbot:~$ . kegbot-server.venv/bin/activate
(kegbot-server.venv)kegbot@my-kegbot:~$ kegbot version
kegbot-server 1.1.0
Disable DEBUG mode
Once you’ve finished setting up the system, it’s a good idea to disable DEBUG mode. Open the local_settings.py file in an editor::
kegbot@my-kegbot:~$ nano ~/.kegbot/local_settings.py
Find DEBUG = True and replace with DEBUG = False, save and close the file.
Configure e-mail
Unlike most Kegbot options, e-mail configuration cannot be done in the browser. See the e-mail configuration portion of the Kegbot Server Install Guide for instructions.
