If anyone here is familiar with TWRP, shoot me a PM.
Samsung’s do not work with kegbot, they lack support of USB host mode. In therory any tablet that supports usb host mode should work. Ones with a dedicated power supply seem to work with less hassle. The page you are looking for that covers verified tablets is
The following was also posted to Mikey’s support thread…
Update:
I finally found another Nexus 7 to borrow and it works! I ran through the same procedure on both (wipe back to stock, starting over, then moving forward with the kangaroo zip) and the borrowed one works great while mine doesn’t. No idea what the issue is but I’m going to keep at it.
Thanks to Josh and Mikey
I see above I need to edit the local_settings.py file however as all I have is a command line, I don’t know the command to download (and then re-upload) the file.
I’m not familiar with what the PO has on this so it taking me time to figure out. I got into the section the mentions OTG however I am unable to change any of the settings.. .
I’m curious about the “Size” of the droplet needed to run the server. I’ve had a server set up on a Raspberry and it its terribly slow at the 512 RAM.
I was also think maybe you could see if some one has a differt tablet (like an Acer Iconia A210 or a ViewSonic VSD241) that would let you install the app and try it..
I thought it worked fine as the smallest. However it did seem to hang when restoring a back up.
